certificate import problem
sathappan
Level 4
Level 4
I have a problem in the certificate import while terminating SSL on the csm-ssl module.
During the SSL termination , while configuring the ?crypto ca trustpoint trustpoint_name?
We need to specify the enrollment url and the password.
The password can be obtained from http://localhost/certsrv/mscep/mscep.dll and we need to specify this url in the enrollment url command.
But we are getting the password only from https://localhost/certsrv/mscep/mscep.dll
And when this url is specified under the enrollment url command , the certificate is not imported.
can someone help?
with thanks and regards
sathappan.s
umedryk
Level 11
Level 11
In this case you will have to re-generate the certificate
