Cisco ACE 4710 Licence Issue
s.mansha
I urgently need some help/advice on this issue, I have 2 ACE units (4710's) for our development environment, one with 0.5GB licence and the other one has the default 1GB licence (which is not applied). We need to connect these in a redundant manner so as to match our production environment (where both prod. units have 0.5G licence). Can we change (downgrade) the default licence (which is higher spec.) to a 0.5GB licence so that it matches the rest of the units (both in prod. and dev. environments) and get the failover functionality working or will we need to purchase the 0.5GB licence.
Saj
Here are the details of the licences for the units in question...
ACE01/Admin# sh license status
Licensed Feature                            Count
Compression Performance in Mbps             100
Web Optimization Concurrent Conns.          50
SSL transactions per second                 100
Virtualized contexts                        5
Module bandwidth in Gbps                    0.5
ACE01/Admin#
ACE01/Admin# sh license usage
License                      Ins   Lic    Status   Expiry Date   Comments
                                  Count
ACE-AP-C-UP1                  No     -    Unused                 -
ACE-AP-C-UP2                  No     -    Unused                 -
ACE-AP-C-UP3                  No     -    Unused                 -
ACE-AP-01-LIC                 No     -    Unused                 -
ACE-AP-01-UP1                 No     -    Unused                 -
ACE-AP-02-LIC                 No     -    Unused                 -
ACE-AP-02-UP1                 No     -    Unused                 -
ACE-AP-04-LIC                 No     -    Unused                 -
ACE-AP-04-UP1                 No     -    Unused                 -
ACE-AP-04-UP2                 No     -    Unused                 -
ACE-AP-VIRT-5                 No     -    Unused                 -
ACE-AP-500M-LIC               Yes    1    In use   never         -
ACE-AP-VIRT-020               No     -    Unused                 -
ACE-AP-C-100-LIC              Yes    1    In use   never         -
ACE-AP-C-500-LIC              No     -    Unused                 -
ACE-AP-C-500-UP1              No     -    Unused                 -
ACE-AP-OPT-50-K9              Yes    1    In use   never         -
ACE-AP-C-1000-LIC             No     -    Unused                 -
ACE-AP-C-2000-LIC             No     -    Unused                 -
ACE-AP-OPT-LIC-K9             No     -    Unused                 -
ACE-AP-OPT-UP1-K9             No     -    Unused                 -
ACE-AP-SSL-05K-K9             No     -    Unused                 -
ACE-AP-SSL-07K-K9             No     -    Unused                 -
ACE-AP-SSL-100-K9             Yes    1    In use   never         -
ACE-AP-SSL-UP1-K9             No     -    Unused                 -
ACE-AP-SSLUP-5K-K9            No     -    Unused                 -
ACE-AP-VIRT-020-UP            No     -    Unused                 -
ACE01/Admin#
ACE01/Admin# sh ft peer status
Peer Id                      : 1
State                        : FSM_PEER_STATE_COMPATIBLE
Maintenance mode             : MAINT_MODE_OFF
SRG Compatibility            : COMPATIBLE
License Compatibility        : INCOMPATIBLE
FT Groups                    : 1
ACE01/Admin#
ACE02/Admin# sh license status
SSL transactions per second                 1000
Module bandwidth in Gbps                    1.0
ACE02/Admin#
ACE02/Admin# sh license usage
                                  Count
ACE-AP-500M-LIC               No     -    Unused                 -
ACE-AP-C-100-LIC              No     -    Unused                 -
ACE-AP-OPT-50-K9              No     -    Unused                 -
ACE-AP-SSL-100-K9             No     -    Unused                 -
ACE02/Admin#
ACE02/Admin# sh ft peer status
Peer Id                      : 1
FT Groups                    : 1
ACE02/Admin#
Jorge Bejarano
Level 4
Level 4
Mansha,
You could downgrade/uninstall the license and re-install it later ...
As long as it is a permanent license (i.e. not a demo/temp license),
this should be quite fine.
Mark it if you consider it useful.
Jorge
Hi Jorge,
ACE01; has the following licence applied:
installed license: ACE-AP-500M-LIC ACE-AP-C-100-LIC ACE-AP-OPT-50-K9 ACE-AP-SSL-100-K9
ACE02; does not have any licence applied, do you know if I can use the above licence from ACE01 on ACE02?
installed license: no feature license is installed.
I am not sure what you mean by downgrade/unistall? would we have to purchase the above licence?
Would really appreciate it if you could reply back a.s.a.p.
Saj
