Cisco ACE load balancer
techranga
Community Member
   We are using Cisco ACE 4710 for load balancing the servers. The predictor used is 'least connections'.
Have observed the below;
The number of connections for a particular server in a serverfarm is 15 in the Cisco ACE.
The actual number of users in that server is 6.
All the users access using the VIP.
Still i couldn't understand why there is difference in the number of users in the server and the load balancer statistics.
Would appreciate your help.
Ranga
Marko Leopold
Level 6
Level 6
Hello Ranga!
Your ACE counts the number of TCP-connections. The ACE does not know about the number of users in your application.
Cheers
Marko
Hello Marko,
     Thanks for your response. Just correct whether my understanding is correct ?
Termianl server VIP    --->    4 physical servers TS. TS1, TS2, TS3 and TS4.
When a user logins to the VIP, the user is directed to any one of the physical server ex. TS2 ( a TCP connection ).
So each time a user logs in using the VIP, it hits the physical server. The count in LB should match the users in the physical TS.
Correct me if my understanding is wrong ?
Ranga
