Client Authentication Problem!!
alfiesummers
Community Member
Hello all,
I am having issues getting the CSS to present web pages after I select my local certificate. I have verified access to the page works with SSL without using Client Authentication. When I enable client authentication I get prompted, I select the cert, and then I get "Page cannot be displayed". Packet captures show successful SSL handshakes and then nothing happens. I am running WebNS 07.50.0.04.
Has anyone come across this issue and resolved it before? The ssl stats show a successful client authentication also!
Alfie
Gilles Dufour
There were several bug fixed since your version of code and a few of them were related to client authentication.
I think it would be wise to first upgrade to the latest 7.50 image and if the problem persist, send us the data you have [trace, config, show ...]
thanks,
Gilles.
Thanks Giles,
I will give this a try and let you know how I get on.
Alfie
