Configuring two Client VLANs on ACE module
jesse.carter
Community Member
Can you configure two client VLANs on a ACE context? It is need to transition from one IP address scheme to another, so both IP addresses are accessible at the same time until the transition is complete. Can anyone help?
Kristopher Martinez
Yes you can configure multiple vlans within a context. You may want to enable MAC sticky to ensure that your return traffic goes to the correct vlan:
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A2/configuration/rtg_brdg/guide/vlansif.html#wp1061115
Kris
Thanks...
I found the solution eariler. It works perfectly.
