content engine 510 - transparent proxy stand-alone
omerlin98000
Community Member
Hello to all,
after studying architecture examples about Content Engine 510, I found that there is two modes:
1) standard proxy
2) transparent proxy
I need the transparent architecture !
But every example about transparent mode seems to include a router or a switch with a particular level of software, that can send http requests to the Content Engine to have cache.
I don't have any of these components.
I simply need to have a Content Engine that receive any kind of IP protocols on one ethernet, and route it to the other ethernet plug, except that if it is http protocol, it will cache the pages.
Is is simply impossible to configure the Content Engine 510 that way ?
Is the transparent proxy mode always requires a router or a switch to give it the http flow ?
If it is possible, where can I find some configuration examples ?
Thanks to help a newbie in content engine...
Olivier
davekbell
Olivier,
You'll need to have a router running wccp in order to redirect http requests to the cache. Withouth this, the cache has no visibilty of traffic on your LAN.
Dave
