Content Engine errors.
sufle
Level 2
Level 2
Hi there,
I'm having some problems with Content Engine.
I would appreciate any help.
It gives following errors:
Jun 12 08:15:59 CE01 wccp: %CE-WCCP-5-500008: WCCP: A new view from
the 25.25.25.25. Change number = 28
Jun 12 08:15:59 CE01 wccp: %CE-WCCP-5-500014: WCCP: New CE notified of
15.16.17.208
Jun 12 08:15:59 CE01 wccp: %CE-WCCP-5-500026: New CE entry being
created for 15.16.17.208 seen by router 25.25.25.25
Jun 12 08:16:07 CE01 wccp: %CE-WCCP-4-500015: WCCP:No assignment sent:
15.16.17.204 not in Router View
Jun 12 08:16:08 CE01 wccp: %CE-WCCP-5-500008: WCCP: A new view from
the 25.25.25.25. Change number = 29
Jun 12 08:16:08 CE01 wccp: %CE-WCCP-5-500014: WCCP: New CE notified of
15.16.17.204
Jun 12 08:16:08 CE01 wccp: %CE-WCCP-5-500026: New CE entry being
created for 15.16.17.204 seen by router 25.25.25.25
Jun 12 08:16:17 CE01 wccp: %CE-WCCP-5-500019: WCCP: New WC in compute
assign 15.16.17.204
Jun 12 08:16:40 CE01 wccp: %CE-WCCP-3-500001: HTTP Proxy may be down,
keepalives halted!
Jun 12 08:20:54 CE01 java: %CE-CMS-4-700001: ds_getStruct got error :
50 for key stat/cache/http/perf/throughput/requests/sum connection 5
Jun 12 08:20:54 CE01 java: %CE-CMS-4-700001: ds_getStruct: unable to
get `stat/cache/http/perf/throughput/requests/sum' from dataserver
Jun 12 08:20:54 CE01 java: %CE-CMS-4-700001: unable to get http
request throughput stats(error 50)
4 for key stat/cache/https/request connection 5
get `stat/cache/https/request' from dataserver
Jun 12 08:20:54 CE01 java: %CE-CMS-4-700001: unable to get https
request throughput stats(error 4)
4 for key stat/cache/ftp connection 5
get `stat/cache/ftp' from dataserver
ftp-over-http request throughput stats(error 4)
4 for key stat/cache/http/usage/cpu/sum connection 5
get `stat/cache/http/usage/cpu/sum' from dataserver
Jun 12 08:20:54 CE01 java: %CE-CMS-4-700001: unable to get cpu
stats(error 4)
sufle
Level 2
Level 2
If anybody need some more information, please ask me whatever you need.
thanks again.
Hi guys,
I am really out of ideas!!!
I've updated software couple times already.
but nothing helps.
it still gives same error:
Jun 16 14:23:01 ponent exec_show_stats: %CE-CLI-3-170013: item stat/cache/http/usage/cpu/sum not found not found in dataserver
Jun 16 14:23:01 ponent exec_show_stats: %CE-CLI-3-170013: item stat/cache/http/request not found not found in dataserver
Jun 16 14:23:01 ponent exec_show_stats: %CE-CLI-3-170013: item stat/cache/https/request not found not found in dataserver
Jun 16 14:23:01 ponent exec_show_stats: %CE-CLI-3-170013: item stat/cache/https/requests not found not found in dataserver
Jun 16 14:23:01 ponent exec_show_stats: %CE-CLI-3-170013: item stat/cache/ftp-native not found not found in dataserver
Jun 16 14:23:01 ponent exec_show_stats: %CE-CLI-3-170013: item stat/cache/ftp not found not found in dataserver
Jun 16 14:23:02 ponent exec_show_stats: %CE-CLI-3-170013: item stat/wccp/bypass not found not found in dataserver
Jun 16 14:23:52 ponent exec_rule: %CE-CLI-3-170013: Verifier not responding. when setting cfg/gl/cache/rule/stat/show (Error number: 32)
Jun 16 14:23:52 ponent exec_show_stats: %CE-CLI-3-170013: item stat/cache/http/err not found not found in dataserver
Jun 16 14:23:52 ponent exec_show_stats: %CE-CLI-3-170013: item stat/cache/https/err not found not found in dataserver
Jun 16 14:24:37 ponent cfg_bin_urlfilter: %CE-CLI-3-170013: Verifier didn't respond. Need to re-register verifier. when setting /cfg/gl/cache/urlfilter/http/enable (Error number: 64)
Jun 16 14:24:45 ponent java: %CE-CMS-4-700001: ds_getStruct got error : 4 for key stat/cache/http/perf/throughput/requests/sum connection 5
Jun 16 14:24:45 ponent java: %CE-CMS-4-700001: ds_getStruct: unable to get `stat/cache/http/perf/throughput/requests/sum' from dataserver
Jun 16 14:24:45 ponent java: %CE-CMS-4-700001: unable to get http request throughput stats(error 4)
Jun 16 14:24:45 ponent java: %CE-CMS-4-700001: ds_getStruct got error : 4 for key stat/cache/https/request connection 5
Jun 16 14:24:45 ponent java: %CE-CMS-4-700001: ds_getStruct: unable to get `stat/cache/https/request' from dataserver
Jun 16 14:24:45 ponent java: %CE-CMS-4-700001: unable to get https request throughput stats(error 4)
Jun 16 14:24:45 ponent java: %CE-CMS-4-700001: ds_getStruct got error : 4 for key stat/cache/ftp connection 5
Jun 16 14:24:45 ponent java: %CE-CMS-4-700001: ds_getStruct: unable to get `stat/cache/ftp' from dataserver
Jun 16 14:24:45 ponent java: %CE-CMS-4-700001: unable to get ftp-over-http request throughput stats(error 4)
Jun 16 14:24:45 ponent java: %CE-CMS-4-700001: ds_getStruct got error : 4 for key stat/cache/http/usage/cpu/sum connection 5
Jun 16 14:24:45 ponent java: %CE-CMS-4-700001: ds_getStruct: unable to get `stat/cache/http/usage/cpu/sum' from dataserver
Jun 16 14:24:45 ponent java: %CE-CMS-4-700001: unable to get cpu stats(error 4)
Jun 16 14:24:47 ponent java: %CE-CMS-4-700001: ds_getStruct got error : 4 for key stat/cache/http/perf/throughput/requests/sum connection 5
Jun 16 14:24:47 ponent java: %CE-CMS-4-700001: ds_getStruct: unable to get `stat/cache/http/perf/throughput/requests/sum' from dataserver
Jun 16 14:24:47 ponent java: %CE-CMS-4-700001: unable to get http request throughput stats(error 4)
Jun 16 14:25:15 ponent cfg_bin_urlfilter: %CE-CLI-3-170013: Verifier didn't respond. Need to re-register verifier. when setting /cfg/gl/cache/urlfilter/http/enable (Error number: 64)
Jun 16 14:25:24 ponent writemem.sh: %CE-CLI-2-170054: running-config has 0 line(s)
Jun 16 14:25:24 ponent exec_copy: %CE-CLI-3-170055: Copy running-config to startup-config failed!. status(1.20)
please, any suggestion would be appreciated.
