Content Switch not passing udp traffice port 161 & 162
astanislaus
Level 2
Level 2
Our Version:
CSS 11050 SW Version: 5.00 Build 503
Noticed that:
Release Note for the Cisco 11000 Series Content Services Switch (Software Version 5.00.0.45) says:
The CSS does not set up flows if the source or destination port is designated as port 67, 68, 137, 138, 161, 162, 520, or 8089 (UDP only).
Do I have to go to the latest version to resolv ethis problem? Any suggestion on which version to use?
Gilles Dufour
upgrade to the latest 6.10 version in order to get the following command
gduf-css11000-1(config)# flow-state 161 udp ?
flow-disable Disable flow creation for this entry
flow-enable Enable flow creation for this entry
Gilles.
