Cookie based Load Balancing
drakewhite
Community Member
If 3 Real servers in a non-load balancing environmet are setting session cookies with diffrenet cookie names e.g.
server1 response
set-Cookie: SESSIDSAAAAAA=DMNNNELCECNCKDIIDCPOIMGG
Server2 response
set-Cookie: SESSIDSBBBBBB=DAAMMNELCECNCKPYTWPOIPOP
Server3 response
set-Cookie: SESSIDSCCCCCC=POHYTUOIPOPPLKJHTERIQOKJ
then how can CSM be configured with cookie based stickiness.
I tried cookie insert on CSM with NULL value Assigned to "COOKIE_INSERT_EXPIRATION_DATE".
It resulted in two set cookie responses (one from server and one from CSM).
I am wondering how csm will react ( cookie insert is used) if client request carries two cookie name-value pairs.
clients are behind megaproxy so cookie based stickiness is needed.
Gilles Dufour
if you look into a http client request you will see that many times there are more than 1 cookies.
The most important is to make sure the CSM insert a cookie with a different name.
Create your own name.
The client will receive both the csm cookie and the server cookie and will send both when opening a new connection.
The CSM is able to locate its own cookie in the list and do the stickyness.
Gilles.
