Cookie stickiness configuration issue with Cisco ACE
anbushan74
We have configured a ACE (in standby mode) with ip netmask stickiness and wanted to configure cookie stickiness for a remedy server placed behind the ace. BMC has said that they use JSESSIONID field on the remedy application and i want to know the procedure for configuring ace to see this field and deploy cookie stickiness feature on the ace.
We tried configuring the ace to learn the cookie string dynamically and tried to insert the cookie in the server response to the client but both methods have failed and the user is not able to see the remedy app webpage in both occassions.
Are there any pre-requisites to be configured on the ace before configuring cookie stickiness feature?   We would appreciate your timely response.
Thanks in advance.
sivaksiv
Refer the document below for sample configuration. If this still doesn't work a full config and sniffer capture required to verify this.
http://docwiki.cisco.com/wiki/Session_Persistence_Using_Cookie_Learning_on_the_Cisco_Application_Control_Engine_Configuration_Example
Siva
