Cookie stickyness issues - ACE
quesne02
Another issue where I have been asked to integrate an app and do cookie stickyness for a web app.  The config is good from the ACE perspective, but the problem is that the cookie is not present in the packets until a login to the app happens.
  This means that the first few packets to get to the login page does not contain any cookie information, but once properly logged in, no problem.  Is there an easy way "bypass" the creation of the sticky entries untill the cookie is seen ? or what am I missing to just do the sticky entry only if the cookie is present.
thanks
Surya ARBY
Level 10
Level 10
please post your config.
The best practice for web based applications is to use cookie insertion with the "browser-expire" flag set.
Here is the config, edited a bit to what is pertinent
probe https SrvCat_HTTPS_7143_Probe
  description Service Catalog HTTPS probe on port 7143
  port 7143
  interval 15
  passdetect interval 5
  passdetect count 2
  expect status 200 302
  header User-Agent header-value "Mozilla/4.0"
probe https SrvCat_HTTPS_7243_probe
  description Service Catalog HTTPS probe on port 7243
  port 7243
  interval 15
  passdetect count 2
probe https SrvCat_HTTPS_7343_probe
  description Service Catalog HTTPS probe on port 7343
  port 7343
  interval 15
  passdetect count 2
probe https SrvCat_HTTPS_7443_probe
  description Service Catalog HTTPS probe on port 7443
  port 7443
  interval 15
  passdetect count 2
probe http SrvCat_HTTP_7180_Probe
  description Service Catalog HTTP probe on port 7180
  port 7180
  interval 15
  passdetect count 2
probe http SrvCat_HTTP_7280_probe
  description Service Catalog HTTP probe on port 7280
  port 7280
  interval 15
  passdetect count 2
probe http SrvCat_HTTP_7380_probe
  description Service Catalog HTTP probe on port 7380
  port 7380
  interval 15
  passdetect count 2
probe http SrvCat_HTTP_7480_probe
  description Service Catalog HTTP probe on port 7480
  port 7480
  interval 15
  passdetect count 2
parameter-map type connection for_switch_mode
  set timeout inactivity 300
rserver host was61nstga
  ip address 192.168.96.94
  inservice
rserver host was61nstgb
  ip address 192.168.96.102
  inservice
serverfarm host SrvCat_HTTPS_ServerFarm
  rserver was61nstga 7143
    probe SrvCat_HTTPS_7143_Probe
    inservice
  rserver was61nstga 7243
    probe SrvCat_HTTPS_7243_probe
    inservice
  rserver was61nstga 7343
    probe SrvCat_HTTPS_7343_probe
    inservice
  rserver was61nstga 7443
    probe SrvCat_HTTPS_7443_probe
    inservice
  rserver was61nstgb 7143
    inservice
  rserver was61nstgb 7243
    inservice
  rserver was61nstgb 7343
    inservice
  rserver was61nstgb 7443
    inservice
serverfarm host SrvCat_HTTP_ServerFarm
  rserver was61nstga 7180
    probe SrvCat_HTTP_7180_Probe
    inservice
  rserver was61nstga 7280
    probe SrvCat_HTTP_7280_probe
    inservice
  rserver was61nstga 7380
    probe SrvCat_HTTP_7380_probe
    inservice
  rserver was61nstga 7480
    probe SrvCat_HTTP_7480_probe
    inservice
  rserver was61nstgb 7180
    inservice
  rserver was61nstgb 7280
    inservice
  rserver was61nstgb 7380
    inservice
  rserver was61nstgb 7480
    inservice
sticky http-cookie JSESSIONID HTTP_Stickyness
  timeout 720
  replicate sticky
  serverfarm SrvCat_HTTP_ServerFarm
sticky http-cookie JSESSIONID HTTPS_Stickyness
  timeout 720
  replicate sticky
  serverfarm SrvCat_HTTPS_ServerFarm
sticky ip-netmask 255.255.255.255 address source SrvCat-IP-Sticky
  timeout 20
  replicate sticky
sticky ip-netmask 255.255.255.255 address source SrvCat-HTTP-IP-Sticky
  timeout 20
  replicate sticky
sticky ip-netmask 255.255.255.255 address source SrvCat-HTTPS-IP-Sticky
  timeout 20
  replicate sticky
class-map match-any VIP-SrvCat-HTTPS
  3 match virtual-address 165.115.xxx.yyy tcp eq https
class-map match-any VIP-SrvCat-WWW
  2 match virtual-address 165.115.xxx.yyy tcp eq www
policy-map type loadbalance http first-match SrvCat-HTTP-LoadBalance-Policy
  class class-default
    sticky-serverfarm SrvCat-HTTP-IP-Sticky
policy-map type loadbalance http first-match SrvCat-HTTPS-LoadBalance-Policy
  class class-default
    sticky-serverfarm SrvCat-HTTPS-IP-Sticky
policy-map type loadbalance http first-match SrvCat-LoadBalance-Policy
  class class-default
    sticky-serverfarm SrvCat-IP-Sticky
policy-map multi-match SLB-SrvCat-Policy
  class VIP-SrvCat-HTTPS
    loadbalance vip inservice
    loadbalance policy SrvCat-HTTPS-LoadBalance-Policy
    loadbalance vip icmp-reply active
    loadbalance vip advertise active
    connection advanced-options for_switch_mode
  class VIP-SrvCat-WWW
    loadbalance policy SrvCat-HTTP-LoadBalance-Policy
  class class-default
interface vlan 859
  ip address 172.16.166.85 255.255.255.240
  alias 172.16.166.84 255.255.255.240
  peer ip address 172.16.166.86 255.255.255.240
  access-group input anyone
  access-group output anyone
  service-policy input remote_management_allow_policy
  service-policy input SLB-SrvCat-Policy
  no shutdown
It's expected as the cookie you want to track is only created in the application when the user logs in, it's related to the session within the app.
Try this type of persistance :
sticky http-cookie HTTP_ACE_INSERT HTTP_Stickyness
cookie insert browser-expire
replicate sticky
  class class-default
    sticky-serverfarm HTTP_Stickyness
For the HTTPS part, no L7 persistence available as you don't perform SSL termination on the ACE, only source ip persistence is accurate.
Any update ?
