CS-100 and 6509 network
mrembetsy
All,
I have a 6509 with a sup2 and msfc2 in it. Currently I have a /27 created for a client that is all routable public ips. One of our CS-100 arrowpoint/cisco content switches is on this vlan. It used to be behind a pix with NAT. Since we moved it, I now have the config to a point where it will balance the load and have the right stickiness. The problem I am having is that whenever anyone hits the VIP and the load balancer directs the traffic to a server if you look in the serverlogs you will see the ip of the CS-100 and or the VIP, not the client who hit the vip. Will this cs-100 work in this type of environment? Since it is a CS-100 it won't trunk without the Gigic interface (which isn't on this model) and therefore I have had to 'bridge' to my vlan. Has anyone gotten one to work in this manner. I can provide config file for anyone, no problem. Feel free to email me or reply to the post. I have tried pretty much everything i can think of.
Thank you,
Mike
mrembetsy@corsis.com
mrembetsy
All,
thanks for anyone who even looked at my posting. I figured out the problem. I only had 1 interface plugged into the 3548. so I plugged in another 3500's series switch to e2 and then setup the load balancing, removed the group and volia. Everything works like a charm.
Thanks all
Mike
