CSM Direct Access but ICMP doesn't work
whitema
I've configured direct access through the CSM as recommended by several people. I can telnet to a device on the server VLAN just fine. However, I cannot ping it.
I must have ICMP pass for monitoring purposes.
My config:
vlan 485 client
ip address 10.100.250.11 255.255.255.224
gateway 10.100.250.1
alias 10.100.250.9 255.255.255.224
vlan 410 server
ip address 10.100.100.3 255.255.254.0
alias 10.100.100.1 255.255.254.0
serverfarm DA_V410
no nat server
no nat client
predictor forward
vserver DA_V410
virtual 10.100.100.0 255.255.254.0 any
serverfarm DA_V410
persistent rebalance
inservice
ip route 10.100.100.0 255.255.254.0 10.100.250.9
Any suggestions?
Gilles Dufour
do a 'clear mod csm conn'.
If you did try the ping before the config above was in place, the CSM may still have in its cache the incorrect flow information.
You can check first if this entry exist with the command
'sho mod csm slot conn detail'
Gilles.
