CSS 11150 Booting Problem
zahid.hassan
Level 2
Level 2
Dear All,
After a power outage, one of our CSS is failing to boot up properly. Every time its rebooted, it goes straight to the OFFDM although the Primary boot device has been selected to be Disk. I have formatted the
Disk and loaded a new image, it booted with the new image once and its
Loading to OFFDM every time its rebooted.
I would be really grateful if someone could shed some light on this problem.
Zahid
5 Replies 5
Not applicable
You could check the boot.log for error messages inorder to find out what the problem could be.
Here's the link to Troubleshooting the Boot Process:
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_installation_guide_chapter09186a00800df9dc.html#xtocid1
Hope this is of some help to you.
For details refer:
http://www.cisco.com/univercd/cc/td/doc/product/webscale/css/css_500/getstart/trouble.htm#xtocid4
pknoops
Level 7
Level 7
Zahid,
It really comes down to 2 things.
1. Can you confirm through the OFFDM that the Mgt port has an ip address AND a subnet mask assigned to it. The CSS will not complete the boot process if it has an ip address and no subnet mask.
2. If 1 is ok, then I would have to assume the boot sector on the drive is having problems and the CSS is unable to load the image properly thus putting itself into the OffDM
Let me know what happens
Pete Knoops
Cisco Systems
Pete,
Thank you very much for your reply.
I have entered an IP address and subnet mask for the Mgt. port and the CSS
came up without a problem. After adding few configuration lines, I rebooted
the box it came up without a problem and everything seems to be working fine.
After a few days, I logged on to the box and found that I cannot type in any commands.
Its up and running but It would not take any command or go to the config mode.
I will be really grateful for any further input relating to this problem.
Zahid
Zahid,
OK, so it sounds like the console port is not working properly or maybe it's frozen. The next thing to check is telnet access ? If you can't telnet or access the console, the last thing would be the mgt port via a crossover cable to your PC. If you have no console, telnet, or mgt port access, the last resort is rebooting the CSS during some down time if this box is in a production environment.
After booting the box, should you still have no console, I would recommend opening a TAC case and having the box replaced.
Pete Knoops
Cisco Systems
networks
Community Member
Just a simple thought.....
we had problems with our 2 CSS's early on and there is a known problem with the Flash disks on certain models with a certain revision number and Cisco have a field notice out on CCO about this. We had our FD's changed for HD's as one of them was doing this exact same thing you discribe
We also found if you ran the disk checker and fixed the errors and booted the CSS it worked until it was rebooted again then the same thing happened again.
Don't know whether that helps or not
Simon
