Showing results forĀ
Search instead forĀ
Did you mean:Ā
CSS 11501 Load Balancing Issue
We are facing some issue in load balancing in cisco CSS 11501 as we are not able to access the application  through virtual IP. Below is the ruuning configuration of the CSS:
CSS11501# sh running-config
!Generated on 10/06/2010 16:51:34
!Active version: sg0810106
configure
!*************************** GLOBAL ***************************
  ip route 0.0.0.0 0.0.0.0 132.186.199.1 1
!************************** CIRCUIT **************************
circuit VLAN1
  ip address 132.186.199.145 255.255.255.0
!************************** SERVICE **************************
service Server1
  ip address 132.186.199.243
  port 5001
  protocol tcp
  keepalive port 5001
  active
service Server2
  ip address 132.186.199.246
  protocol tcp
  port 5001
  keepalive port 5001
  active
!*************************** OWNER ***************************
owner L5_Owner
  content L3_Rule
    vip address 132.186.199.146
    protocol tcp
    port 5001
    add service Server1
    add service Server2
    active
  content L5_Rule
    add service Server1
    add service Server2
    protocol tcp
    port 5001
    url "//132.186.199.146:5001/emi"
    active
CSS11501#
Observation : We are able to telnet on VIP: 132.186.199.146 on port 5001,  but not able to access the application.
In Actual scenarion customer access  application by accessing URL: http://132.186.199.243:5001/emi and once he enter this URL in web browser the request redirects ( by server itself)  to URL: https://132.186.199.44:6002/cas/login?service=http%3A%2F%2F132.186.199.243%3A5001%2Femi%2Findex.jsp&acceptStrength=BASIC on backend server for user authenticaton and once user is authenticated then it again redirect to main URL ( http://132.186.199.243:5001/emi ) to access the application but when we are trying to access the application through VIP ( URL: http://132.186.199.146:5001/emi) we are not getting the login page as the request is not gettting redirected to backend server for user authentication.
Please suggest a solution here.
Marko Leopold
Level 6
Level 6
Try it with this configuration please
  content L5_Rule
    add service Server1
    add service Server2
    protocol tcp
    port 5001
    url "/emi"
    active
the URI means the request line in the http-header, which is without ip-address of the server.
Hi Marko,
Thanks for the reply but I have already tried this (/emi) option and also tried /* but no success.
Could anybody please suggest what is the problem here  ??.
The problem is that you are in one-armed mode.
So you need to configure client nat.
Without nating the client ip address, the server response goes back directly to the client and bypasses the CSS.
Therefore the client receives a response from an unknown server ip address (not the vip).
So configure a group.
For example
group Client
    add destination service Server1
     add destination service Server2
    active
Also, remove the url command from your content rule.
It is useless in your case and will just make performance worst.
Gilles.
Hi Gilles,
Thanks for the reponse and your suggestion as after configuring the clinet NAT we are able to access the application through CSS and its working fine.
Thanks again for your help.
