CSS 11503: Management port default gateway
alex.alexander
Hello all,
I tried to configure a default gateway on the managemet interface of a CSS 11503, running WebNS version 7.10 Build 3. The problem is that gateway doesn't work.
I tried to find if there is a bug linked to my issue, however without success.
Is there someone who has already tested this?
Does it work?
Is there a bug linked to this issue?
Thanks in advance for any answer.
Best regards.
Alex
Gilles Dufour
the default gateway for the management interface is only being used during device boot sequence in order to perform network boot.
You can static routes on the management port but they can't overlap with the regular routing table.
Check the following doc
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_getting_started_guide_chapter09186a00802928d9.html#wp1155886
Gilles.
