CSS 11503 with 7.3 code SSL issue
unitus
Community Member
We have redundany Cisco 11503 content switches. Recently we attempted an upgrade from 7.3 code to 7.5 code. After doing so, none of the SSL streams would work (we terminate SSL for several servers on the SSL module). The only way to establis the SSL streams again and pass that traffic was to go back to the 7.3 code. Can anyone assist? Also, does anyone know if the new code allows you to add SSL certs and make them active without taking down the SSL mod?
Thanks!
Gilles Dufour
for the ssl issue, you will need to do some more troubleshooting.
- Was the traffic making it to the CSS ?
-'sho summary' and 'sho serv summary'.
- Was the CSS decrypting the traffic ?
- Do you see any hit on the decrypted rule ?
- sniffer trace ?
- 'sho ssl statistics' before and after tests ?
For the new features of 7.50, have a look at
http://www.cisco.com/en/US/products/hw/contnetw/ps792/prod_release_note09186a00804174d1.html#wp171185
"SSL proxy list modification without suspending a service"
Gilles.
unitus
Community Member
Hi Gilles,
I don't have much more information, as this was done on production gear and we had to restore service ASAP. I can tell you that the code change was the only change made. The SSL requests were hitting the CSS SSL module, but the module was not opening flows and processing the streams. The servers (services) behind the CSS were alive at the time. As soon as code was brought back to the 7.3 level, SSL streams flowed like normal. I will try to get some more information from one of the other guys on my team that did the upgrade.
Frank
Frank,
a lot of things changed regarding the ssl module.
Did you load the very latest 7.50 version ?
We are doing many tests internally to validate the software, this is why I'm surprised nothing worked and also why I would like to get as much info as possible on what you saw.
Gilles.
Hi Gilles,
Everything worked after the upgrade EXCEPT the SSL flows. I don't have the exact error (I'm trying to locate the capture) but the CSS processed all traffic correctly except for SSL flows. It would not process SSL streams after the upgrade of code. As soon as 7.3 code was put back on, everything worked fine. We are looking at another maintenance window in the next 45-60 days and want to ensure a successful upgrade. We will plan on the latest rev of 7.5x but just not sure why the previous upgrade failed with regards to SSL.
