CSS and routing
snandigam
Community Member
Please refer to the below config:
I am trying to reach vlan3. Can't at the moment. Is the below config valid?
ip route 0.0.0.0 0.0.0.0 172.24.17.241 1
!************************* INTERFACE *************************
interface e2
description "DMZ"
interface e3
bridge vlan 3
description "Internal"
interface Ethernet-Mgmt
description "Management"
!************************** CIRCUIT **************************
circuit VLAN1
ip address 172.24.17.103 255.255.255.0
circuit VLAN3
ip address 172.19.112.5 255.255.248.0
Gilles Dufour
yes this is correct.
Do a 'show phy' to see the status of the physical interfaces.
Make sure e3 is up.
Do a 'sho arp' to see if you have any arp entries on e3.
Try to ping a device one e3 from the css.
Finally, make sure the device on e3 uses the CSS as the default gateway.
Gilles.
