CSS Console Cable
ltrasmundi
Visitor
I have a Cisco CSS 11001 that's been sitting around for a while and I'm trying to console into it. I don't have the original cable that came with it and using a standard molded Cisco console cable isn't working. I've checked the manual online and the terminal settings are correct, so I can only assume it's the cable. Any ideas?
Diego Vargas
The CSS 11000 series need a different cable, this link explains how to build it:
http://www.cisco.com/en/US/products/hw/contnetw/ps789/products_tech_note09186a00800a3f28.shtml
Also make sure to set Flow Control to none on the port settings.
Hope it helps!!
I now have it working, I made a cable based on the document you recommended. Thanksyou!
