CSS on multiple subnets and separate load balancing
tholmes
Level 4
Level 4
I've a situation where I need to load balance incoming clients on subnet A to 3 real servers on subnet B - no problems there.
But I also need to load balance different clients on subnet C to 3 other servers on subnet D and clients on subnet E to 2 servers on subnet F.
Basically I want to use the CSS for 3 different load balancing operations.
Rather than using 3 separate CSS11503s can I do all this with multiple VLANs on the LAN switches and 1 CSS?
Any help appreciated
Regards Tony
Gilles Dufour
you can have as many vlan as you want.
So yes you can do what you want.
Just be aware that the CSS can route as well between those vlans, so if you separation between them you may have to use ACL.
Gilles.
Gilles Dufour
Gilles.
Excellent, many thanks Gilles for the speedy reply, I'll be happy to give this a top rating
Cheers mate
Tony
