CSS - Radius authentication problem
m.loli
Community Member
for a customer we need to configure Radius authentication working like this:
- CSS administrator login to device at user level
- then switch to "enable" mode using a superuser level account.
First login to CSS with a Radius account at user level works fine, but (after enable command) the login at superuser level doesn't work neighter with Radius account nor with local superuser account.
Ver.: 08.10.4.01
This is the configuration:
radius-server primary 10.113.212.17 secret XXX auth-port 1645
radius-server source-interface 10.113.212.32
sntp primary-server 10.113.205.1 version 3
date european-date
radius-server secondary 10.113.197.24 secret XXX auth-port 1645
radius-server dead-time 15
radius-server retransmit 15
radius-server timeout 15
virtual authentication primary radius
virtual authentication secondary local
username ZZZ des-password ZZZ superuser
Any idea?
Thanks in advance.
Gilles Dufour
is your server correctly configured as described at :
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v8.10/configuration/security/guide/Radius.html#wp1108380
"From the Group Settings section of the Cisco Secure ACS HTML interface, click the IETF RADIUS Attributes, [006] Service-Type checkbox. Then select Administrative. Administrative is required to enable RADIUS authentication for privileged user (SuperUser) connection with the CSS. "
Gilles.
