CSS11501 load-balancing SMTP and LDAP servers
MARC MONTANARI
Can anybody provide me with samples of configuration to load-balance SMTP & LDAP servers with CSS ? I feer having the same problem as with FTP when the session is initiated from the server side and that we have to make some special adds-on to the config ?
vmoopeung
Level 5
Level 5
Load balancing should work fine on the CSS. I am sure that there is some confiugaration issue. Can you post the configuration so that we can check where the problem is?
