EtherChannel problem on Nexus 7000
huntlee
Dear NetPro gurus,
One of my customer is trying to setup an EtherChannel (LACP) on a pair of Nexus 7000.  However, doesn't matter what we do, the port Eth 1/17 always become suspended.  We have tried swapping fiber cables and also swapping SFPs, but no help.
The 1st Nexus 7010 - called 'VIWLRCA'
The 2nd Nexus 7010 - called 'VIWLRCB'
Originally port eth 1/17 are left as 'normal' trunk port, and we can see eth 1/17 shows up fine under 'show interface brief'
viwlrca-PROD# sh run int eth 1/17
interface Ethernet1/17
  switchport
  switchport mode trunk
  udld disable
  no shutdown
viwlrca-PROD# sh run int eth 1/18
interface Ethernet1/18
  switchport
  udld disable
  channel-group 20 mode active
  no shutdown
viwlrca-PROD# sh int brief
Ethernet      VLAN    Type Mode   Status  Reason                   Speed     Port
Interface        Ch #
Eth1/17       1       eth  trunk  up      none                        10G(S) --
Eth1/18       1       eth  trunk  up      none                        10G(S) 20
Eth1/19       --      eth  routed down    SFP not inserted           auto(S) --
Eth1/20       --      eth  routed down    SFP not inserted           auto(S) --
Eth1/21       --      eth  routed down    Administratively down      auto(S) --
Eth1/22       --      eth  routed down    Administratively down      auto(S) --
Eth1/23       --      eth  routed down    Administratively down      auto(S) --
Eth1/24       --      eth  routed down    Administratively down      auto(S) --
Eth2/25       --      eth  routed down    Administratively down      auto(D) --
Eth2/26       --      eth  routed down    Administratively down      auto(D) --
Eth2/27       --      eth  routed down    SFP not inserted           auto(D) --
Eth2/28       --      eth  routed down    SFP not inserted           auto(D) --
Eth2/29       --      eth  routed down    SFP not inserted           auto(D) --
Eth2/30       --      eth  routed down    SFP not inserted           auto(D) --
Eth2/31       --      eth  routed down    SFP not inserted           auto(D) --
Eth2/32       --      eth  routed down    SFP not inserted           auto(D) --
viwlrca-PROD#
But as soon as I add the Eth 1/17 back onto PortChannel 20
The Eth 1/17 becomes "Suspended" straight away
t
Interface        Ch
Eth1/17       1       eth  trunk  down    suspended                  auto(S) 20
viwlrca-PROD#
viwlrca-PROD# sh port-channel summary
Flags:  D - Down        P - Up in port-channel (members)
        I - Individual  H - Hot-standby (LACP only)
        s - Suspended   r - Module-removed
        S - Switched    R - Routed
        U - Up (port-channel)
        M - Not in use. Min-links not met
Group Port-       Type     Protocol  Member Ports
      Channel
20    Po20(SU)    Eth      LACP      Eth1/17(s)   Eth1/18(P)
viwlrca-PROD#
Config on Primary Nexus:-
!Command: show running-config
!Time: Tue Mar 22 06:04:26 2011
version 5.1(1a)
hostname PROD
cfs eth distribute
feature udld
feature interface-vlan
feature lacp
feature vpc
feature vtp
username admin password 5 $1$pkJaKHZW$Sx4wpDG5xXYkD.QfDk/Cg.  role vdc-admin
no ip domain-lookup
ip domain-name vfc.com
crypto key param rsa label viwlrca-PROD.vfc.com modulus 2048
snmp-server user admin vdc-admin auth md5 0x05f7328e3b39a70be09abc3056ec2819 pri
v 0x05f7328e3b39a70be09abc3056ec2819 localizedkey
vrf context management
spanning-tree pathcost method long
spanning-tree port type edge bpduguard default
spanning-tree loopguard default
spanning-tree vlan 1-3967,4048-4093 priority 4096
interface Vlan1
interface Vlan161
  ip address 172.30.161.2/24
interface Vlan162
  ip address 172.30.162.2/24
interface Vlan163
  ip address 172.30.163.2/24
interface Vlan164
  ip address 172.30.164.2/24
interface Vlan165
  ip address 172.30.165.2/24
interface Vlan190
  ip address 172.30.190.2/24
interface port-channel20
  switchport
  switchport
  udld disable
  no shutdown
  switchport
  udld disable
  no shutdown
interface Ethernet1/19
interface Ethernet1/20
interface Ethernet1/21
interface Ethernet1/22
interface Ethernet1/23
interface Ethernet1/24
interface Ethernet2/25
interface Ethernet2/26
interface Ethernet2/27
interface Ethernet2/28
interface Ethernet2/29
interface Ethernet2/30
interface Ethernet2/31
interface Ethernet2/32
interface Ethernet2/33
interface Ethernet2/34
interface Ethernet2/35
interface Ethernet2/36
interface Ethernet3/25
interface Ethernet3/26
interface Ethernet3/27
interface Ethernet3/28
interface Ethernet3/29
interface Ethernet3/30
interface Ethernet3/31
interface Ethernet3/32
interface Ethernet3/33
interface Ethernet3/34
interface Ethernet3/35
interface Ethernet3/36
line vty
viwlrca-PROD#
Config for Secondary Nexus 7000
VIWLRCB-PROD# sh run
!Time: Tue Mar 22 09:19:22 2011
version 5.1(1a)
hostname PROD
cfs eth distribute
feature lacp
feature vpc
feature vtp
username admin password 5 $1$Lc486EOm$EtKhZWuxGjWWokfeuUsMk.  role vdc-admin
no ip domain-lookup
crypto key param rsa label VIWLRCB-PROD.vfc.com modulus 2048
snmp-server user admin vdc-admin auth md5 0xeb607b54234985ed6740c5fdbb8d84c6 pri
v 0xeb607b54234985ed6740c5fdbb8d84c6 localizedkey
spanning-tree vlan 1-3967,4048-4093 priority 8192
interface Vlan1
  switchport
  switchport
  no shutdown
  switchport
  no shutdown
line vty
VIWLRCB-PROD#
Cheers,
Hunt
seanbowles
Quick troubleshoot:
Default all interfaces in newly created port-channel as well as the port-channel interface, then delete port-channel interface.  Recreate port-channel without the LACP protocol:
interface e1/17,e1/18
  switchport
  channel-group 20 mode on
  no shutdown
  exit
  switchport
  no shutdown
  exit
show port-channel summ
show int trunk
HTH,
Sean
