Flow idle-clean command question
csbowser
Level 2
Level 2
In debug mode, I set the flow idle-clean to a certain value for testing...now I want to go back to default behavior. In the CLI, it states setting the value to zero "disables". Does that mean it disables clean-up, or just disables the idle-clean time setting so that the default behavior is resumed?
Chad
ivillegas
Level 11
Level 11
It just disables the idle-clean time setting
Thanks!
