flow-state 53 udp flow-disable nat-enable impacts
csbowser
After entering the subject command, should I expect to see flows still matching udp/53? I assumed the command would permit the passage of udp/53 and NAT the src/dst but not establish a flow. However, I am still seeing flows established. Any advice?
Chad
lisa.hall
Level 2
Level 2
Yes, you are correct. This command will permit the passage of udp/53 and NAT the src/dst but not establish a flow. Can you post the configuration so that we can troubleshoot further?
