GSLB design issue
syjeon
Level 5
Level 5
Hi.
our company with to make a DR center.
So we are checking the cisco solution,GSS
My question is like below
if there are Active DR and Backup DR
In two DR center, there must be two
PrimaryNS server for delegation to gss?
In my thought, the GSS cound be a Primary NS for dns requesting from .com dns server.
Is it a possible topology?
htarra
Level 9
Level 9
You can do DR Site with OSPF.At site 1, the 2 internet links are of unequal capacity & diference in BW is also more. If u do load-balancing, 1Mbps may be choked throughout the day whereas 5Mbps may not have much on it. It is better to use the 2 links in active /backup configuration using either static routes with AD in case of single ISP, or BGP if multihoming.
