GSS settings distribution
a.gesse
Level 3
Level 3
how often primary GSSM pushes config updates to GSS's and standby master ?
I have 4 GSS's and it seems that some of members are keeping old settings
for long time.
I changed TTL in domain rule and in nslookup I can see that answers that I am
getting may have new value and old value as well.
Same for load balance, some GSS change behavior, some don't.
Is there any way to force GSS to pull out new settings from GSSMP or
force GSSMP to push updates to the members ?
Tried stop/start, disable/enable.
Alex
sbilgi
Level 11
Level 11
I think this is done automatically and the time interval cannot be altered by changing the configuration parameters.
