How ASA handle non-load-balancing traffic
johnsonyu
Can anyone explain how the ASA to handle non-load-balancing traffic (not classified with class-map)? It will be dropped or forwarded?
Jorge Bejarano
Level 4
Level 4
ACE should forward the traffic
As you should be able about this feature to make sure about a better performance of that type of traffic.
Configuring the Switch Mode Feature
Use the switch mode feature to change the way that the ACE handles TCP  connections that are not destined to a particular VIP and those  connections that do not have any policies associated with their traffic.  When you enable this feature, the ACE still creates connection objects  for those TCP sessions that are not destined to the VIP. The ACE  processes these connections as stateless connections, which means that  they do not undergo any TCP normalization checks (for example, TCP  window, TCP state, TCP sequence number, and other normalization checks).
The ACE also creates stateless connections for non-SYN TCP packets if  they satisfy all other configured requirements, for example, ACLs and  other policies. This process ensures that a long-lived persistent  connection passes through the ACE successfully (even if it times out) by  being reestablished by any incoming packet related to the connection.
By default, these stateless connections time out after 2 hours and 15  minutes unless you configure the timeout otherwise. When a stateless  connection times out, the ACE does not send a TCP RST packet but instead  closes the connection silently. Even though these connections are  stateless, the TCP RST and FIN-ACK flags are honored and the connections  are closed when the ACE sees these flags in the received packets.
To change the default timeout for these stateless connections, use the set timeout inactivity command in parameter map connection configuration mode. For details about this command, see theCisco Application Control Engine Module Security Configuration Guide.
The SYN cookie feature still operates normally for these stateless connections that are not destined to any VIP.
The default timeout value of 2 hours and 15 minutes is also applicable to the UDP connections that are not destined to any VIP.
To enable the switch mode feature, use the switch-mode command in configuration mode. The syntax of this command is as follows:
switch-mode
For example, to enable the switch mode feature, enter the following command:
host1/Admin(config)# switch-mode
Hope this helps
Jorge
Additionally, in case you need it you can configure the ACE to drop the traffic. Here you have a link about it:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_1_0/configuration/slb/guide/classlb.html#wp1153095
Hope you find this is useful
Jorge
Cesar Roque
Level 4
Level 4
Hi Tao,
It should route the traffic.  You just need and ACL on the interfaces to permit the traffic.
Cesar R
--------------------- Cesar R ANS Team
