how to set keepalive check for regular expression
rbatchu
We are using css110501 CSS.
Right now the keepalives on services are set using hash values.
But i want to change this keepalives to implement keepalives with regular expression checking.
Any Ideas?
The CSS supports it's own native scripting language that can be used to write keepalives among other things.
Here is an example of a script that I wrote to check a page for some specific text:
! Filename: ap-kal-statpage
! Parameters: None - must be coded in script
! Description:
! This script will attempt to connect to a host and
! "GET" an html page. The script checks the contents
! of the page for a particular string. If the string
! is found, the script passes.
! Failure Upon:
! 1. The correct arguments are not supplied.
! 2. The CSS is unable to connect to the host.
! 3. The string is not found in the page.
no echo
if ${ARGS}[#] "LT" "4"
echo "Usage: ap-kal-portlist \'Hostname Port Page String ...\'"
exit script 1
endbranch
set host "${ARGS}[1]"
set port "${ARGS}[2]"
set page "${ARGS}[3]"
set string "${ARGS}[4]"
set EXIT_MSG "Host ${host} not responding on TCP port ${port}."
socket connect host ${host} port ${port} tcp
socket send ${SOCKET} "GET ${page} HTTP/1.0\n\n"
set EXIT_MSG "String was not found."
socket waitfor ${SOCKET} "${string}" 200
socket disconnect ${SOCKET}
echo "String ${string} was found."
no set EXIT_MSG
exit script 0
d.parks
You would need a scripted keepalive using socket commands for this.
say here is my current service
service ag
ip address 192.168.3.30
keepalive type http
keepalive method get
keepalive port 80
keepalive uri "/ag"
active
I have less idea about scripts.
suppose if u want to configure this keepalive using
a script how to do that?
! Description:
! Failure Upon:
no echo
exit script 1
endbranch
no set EXIT_MSG
exit script 0
Thanks, This script worked very well.
