How to troubleshoot a Gateway ,not registering with the gatekeeper?
admin_2
Level 3
Level 3
Ping to Gatekeeper from gateway is possible.
A debug on cch323 ras, shows that it is timing out, or so it appears.
---------------------x----------------------
After readding the statements, Initially the gateway registers witht he gatekeeper, but after a short time, seconds or minutes, it shows unregistered. This error message is in the log:
%CCH323-2-GTWY_REGSTR_FAILED
Not applicable
1. debug ras on gateway:- Check if the RRQ being sent out to the gatekeeper
and are you getting back a RRJ message or you do get
nothing back.
2.debug ras on gatekeeper:- are you receiving the RRQ from the gateway and
is the gatekeeper sending back RRJ or RCF.
3. For more detailed reason why it wont register, turn
on debug h225 asn1 and look at the RejectionReason.
4. upgrade to the latest h323 software on the gateway.
5. if the gatekeeper see's no RRQ, the n check you config or
look at the output interface for hardware related issue e.g
queue wedge, drop , input errors.etc.
