http not optimizing well
dot10000000000
Hi all,
does anyone have an idea how to optimize web traffic with waas. the wae i have installed have a 4.09 image loaded on it. It optimizes email, printing wafs and other traffic very well but web and oracle traffic hardly get 20% optimization. The link is a satellite link with high latency. could it be the image?
Zach Seils
Level 11
Level 11
Oladotun,
Do you see the HTTP connections with full optimization applied (F,F,F,F)?
Zach
Zach,
Yes it has full optimzation applied. could it be the image? The image on the wae is 4.09b. maybe a 4.017 image will work better than the current one on the box.
Regards.
dotun.
Upgrading to 4.0.17 will provide numerous fixes, so it's worth the effort.
Can you upgrade and see if the problem persists?
Zach
upgrading the image to 4.0.17 does fix the http optimization and sql problem. the image works very well for me.
Regards.
dotun
