HTTPS ans SSL with CSS (No SSL Module)
tevfik
My customers have two server and need to load balance.
These servers initiate SSL.
and VIP address is :
https://erpappl.erp.mis.blabla.tgc:8005
My CSS has no ssl module. An dconfiguration is:
service venice
ip address 10.200.104.32
protocol tcp
port 8005
keepalive type tcp
keepalive port 8005
redundant-index 120
active
service calgary
ip address 10.200.104.33
protocol tcp
port 8005
keepalive type tcp
keepalive port 8005
redundant-index 121
active
owner ERPAPPL
content erpapp_test
add service venice
add service calgary
redundant-index 60
vip address 10.200.104.28
protocol tcp
port 8005
url "/*"
arrowpoint-cookie expiration 00:00:03:00
advanced-balance arrowpoint-cookie
application ssl
active
After this configuration I cannot reach the URL shown above.
Can you help me?
Gilles Dufour
if this is encrypted traffic [HTTPS] the CSS can't see the content of the packet.
So the CSS can't see the url [-> so the command url "/*" is incorrtect and should be removed] and the CSS can't see cookies [so the arrowpoint-cookie command is wrong and should be removed].
If we sell an SSL module, there is a reason 🙂
The only sticky option you can use are :
- sticky based on srcip
- sticky on sslid
The first option [srcip] has a problem with mega proxy [many users being nated with the same ip] and the 2nd option has the problem that it only works with SSLV2 and that some browsers do not use the sslid.
Gilles.
Gilles Dufour
- sticky on sslid
Gilles.
Thanks for reply,
I start from first option 🙂
Changing configuration became like this:
content erpapp_test
add service venice
add service calgary
redundant-index 60
protocol tcp
port 8005
advanced-balance sticky-srcip
active
But I still cannot reach the https://10.200.104.28:85 web page.
Is there any mistake?
P.S . How can add (- sticky on sslid ) row ?
I found the problem.
A mistake configuration in group part.
I used add service instead of add destination service.
I changed now it works.
