Least Connection balance mode problem
alexcheng
Community Member
There are two servers, which are Windows NT with IIS 4.0 and Windows 2003 With IIS 6.0, served by CSS 11506 running WebNS 7.20.206. The load balacing mode configured at CSS is least connection and stickiness enabled as well as flow timeout multipler is 5400.
I experienced a problem that TCP connection counter for Windows 2003 Server (by usng "show rule ... service" command) is not cleared by CSS when the TCP session is closed. However, it seems normal at NT server side. As a result, all new client connection is forwarded into NT server because of least connection balance mechanism. Would anyone tell me how can fix the problem.
Gilles Dufour
Are you saying it is NEVER cleared ?
So it keeps increasing and only for this service ?
What about the 'show service summary'.
Does it show the same number ?
Gilles.
