Memory usage or limitation to max number of flows
csco10260962
Is there a limitation to the max number of flows in use before garbage-collection kicks in. We had a lot of trouble with disconnecting thin-clients to a serverfarm behind a css11501 (using loadbalancing based on sticky-srcip) after adding flow-timeout-multiplier 40 to content rules. The problems ceased, we have about 300 thinclients that could be connected at the same time to the farm. We will be expanding number of thin-clients to 500. And i want to know if there same problems will comeback or if i can increase the flow-timeout-multiplier futher without any problems.
See config below :
!************************** CIRCUIT **************************
circuit VLAN88
ip address 10.61.3.15 255.255.255.0
ip virtual-router 191
ip redundant-interface 191 10.61.3.16
circuit VLAN85
ip address 10.61.2.111 255.255.255.0
ip virtual-router 1
ip redundant-interface 1 10.61.2.113
ip redundant-vip 1 10.61.2.103
ip redundant-vip 1 10.61.2.105
!************************** SERVICE **************************
service sdvdbbts11
ip address 10.61.3.10
active
service sdvdbbts12
ip address 10.61.3.11
active
service sdvdbbts13
ip address 10.61.3.12
active
service sdvdbbts14
ip address 10.61.3.13
active
!*************************** OWNER ***************************
owner SDVDBBTSFH
content SDVDBBTSFH_RULE
add service sdvdbbts13
add service sdvdbbts14
vip address 10.61.2.103
advanced-balance sticky-srcip
sticky-inact-timeout 150
owner SDVDBBTSFHA
content SDVDBBTSFA_RULE
add service sdvdbbts11
add service sdvdbbts12
vip address 10.61.2.105
you have to be in llama mode.
Gilles Dufour
look at 'flow stat' for number of free FCB.
The number of users does not really matters.
What is important is the number of connections.
Gilles.
Hi Gilles,
Thankyou for the information. When i give command "flow statisitics".
I get following output :
flow statistics
AGGREGATE FLOW STATISTICS PER-SP
Flow Manager Statistics - Module 1
Cur High Avg
UDP Flows per second 0 30 0
TCP Flows per second 0 77 3
Total Flows per second 0 77 3
Hits per second 0 30 0
AGGREGATE FLOW STATISTICS PER-PORT
Port Active Total TCP UDP
#e1 53 8900748 49 4
#e8 51 8793167 47 4
I can't see the nummber of free FCBS the 11501 is running 7.10 Build 305 stnd.
