Need help in CSS Nat issue
r-docuyanan
Community Member
I have a set-up below and trying to test out the CSS, i have problem browsing from server towards the internet . It seems that the CSS is blocking it. The default gateway of the servers is 192.168.1.30 which is the circuit vlan ip facing server farm. Is there anything i miss out why its not working?
!*************************** GLOBAL ***************************
no restrict web-mgmt
bridge priority 65000
dns primary 20.0.0.1
ftp-record DEFAULT_FTP 192.168.88.142 anonymous des-password phyfzfqa6f2dheqb
/DOWNLOADS
ip route 0.0.0.0 0.0.0.0 192.168.100.1 1
ip route 192.168.1.0 255.255.255.0 192.168.1.1 1
!************************* INTERFACE *************************
interface e1
description "INSIDE_NETWORK"
bridge vlan 10
interface e2
description "OUTSIDE_NETWORK"
bridge vlan 100
!************************** CIRCUIT **************************
circuit VLAN10
description "SERVERFARM_VLAN"
ip address 192.168.1.30 255.255.255.0
circuit VLAN100
description "WWW_FACING_VLAN"
ip address 192.168.100.30 255.255.255.0
!************************** SERVICE **************************
service SERVER1
ip address 192.168.1.31
protocol tcp
keepalive type http
keepalive port 80
keepalive tcp-close fin
active
service SERVER2
ip address 192.168.1.32
protocol tcp
keepalive type http
keepalive port 80
active
!*************************** OWNER ***************************
owner OWNER
content CRM
vip address 192.168.100.31
add service SERVER1
protocol tcp
port 80
url "/sugarcrm/*"
active
content IIS
vip address 192.168.100.32
add service SERVER2
protocol tcp
port 80
url "/*"
active
Diego Vargas
Hi, try adding s source group to NAT source IP of the traffic sourced from the servers going to the outside, like this:
group outbound
add service SERVER1
add service SERVER2
active
Hope it helps!!
Diego Vargas
group outbound
add service SERVER1
add service SERVER2
active
Hope it helps!!
