Need help to Configure Cisco ACE 4710 Cluster Deployment
Dear Experts,
I'm newbie for Cisco ACE 4710, and still I'm in learning stage. Meanwhile I got chance at my work place to deploy a Cisco ACE 4710 cluster which should load balance the traffic between  two Application Servers based on HTTP and HTTPS traffic. So I was looking for good deployment guide in Cisco SBA knowledge base then finall found this guide.
http://www.cisco.com/en/US/docs/solutions/SBA/February2013/Cisco_SBA_DC_AdvancedServer-LoadBalancingDeploymentGuide-Feb2013.pdf
This guide totally fine with my required deployment model. I have same deployment environment as this guide contains with ACE cluster that connects to two Cisco 3750X (Stack) switches. But I have some confusion places in this guide
This guide follow the "One-armed mode" as a deployment method. But when I go through it further I have noticed that they have configured server VLAN as a 10.4.49.0/24 (all servers reside in it) and Client side VIP also in same VLAN which is 10.4.49.100/24 (even NAT pool also).
My confusion is, as I have learned about Cisco ACE 4710 one-armed mode deployment method, it should has two VLAN segments, one for Client side which client request come and hit the VIP and then second one for Server side. which means besically two VLANs. So please be kind enough to go through above document then tell me where is wrong, what shoud I need to do for the best. Please this is an urgent, so need your help quickly.
Thanks....!
-Amal-
23 Replies 23
Dear Kanwal,
I know if I can find out the solution for my first concern above, it will automatically solve my second concern too. So please help me out for this
Thanks....!
-Amal-
Hi Amal,
With "no preempt" once ACE comes back up it should not take the control back from ACTIVE. If it is then this is ACE misbehaving. Ensure that FT vlan is used dedicatedly for only FT communication. I would also suggest to open a TAC case for further investigation since preempt is configured and still it is taking the control back.
Regads,
Kanwal
Dear Kanwal,
I need quick help for you. Following are the Application LB requirements which I received from my clinet side.
Following detail required for configuring Oracle EBS Apps tier on HA:
  • LBR IP and Name required to configure EBS APPS Tier (i.e, ap1ebs & ap2ebs nodes)
  • Suggested IP and Name for LBR:
    • IP : 172.25.45.x [should be on same 172.25.45 subnet of ap1ebs & ap2ebs nodes]
    • ebiz.xxxx.lk [on port 80 for http protocol accessibility]
    • This LBR IP & name must be resolve and respond on DNS network
Server Farm detail for LBR Setup
Following detail will be use for configuring the LBR:
  • LBR IP and Name :
    • Server Farm Detail for LBR setup:
      • Server 1 (EBS App1 Node, ap1ebs):
        • IP : 172.25.45.19
        • Server Name: ap1ebs.xxxx.lk [ap1ebs hostname is an example, actual hostname will be use]
        • Protocol: http
        • Port: 8000
  • Server 2 (EBS App2 Node, ap2ebs):
    • IP : 172.25.45.20
    • Server Name: ap2ebs.xxxx.lk [ap2ebs hostname is an example, actual hostname will be use]
    • Protocol: http
    • Port: 8000
Since my client needs to access URL ebiz.xxxx.lk which should be resolved by IP 172.25.45.21 (virtual IP) via http (80) before they deploy the app on the two servers I just ran web service on both servers (Linux) and was trying to access http://172.25.45.21 it was working fine and gave me index.html page. Now after my client has deployed the application then when he tries to access the page http://172.25.45.21 he cannot see his main login page. But still my testing web servers are there on both servers when I type http://172.25.45.21 it will get index.html page, but not my client web login page. What can I do for this ?
Following are my latest config :
probe http Get-Method
  description Check to url access /OA_HTML/OAInfo.jsp
  interval 10
  faildetect 2
  passdetect interval 30
  request method get url /OA_HTML/OAInfo.jsp
  expect status 200 200
probe udp http-8000-iRDMI
  description IRDMI (HTTP - 8000)
  port 8000
probe http http-probe
  description HTTP Probes
  interval 10
  faildetect 2
  passdetect count 2
  request method get url /index.html
probe https https-probe
  description HTTPS traffic
  interval 10
  faildetect 2
  passdetect count 2
  ssl version all
probe icmp icmp-probe
  description ICMP PROBE FOR TO CHECK ICMP SERVICE
rserver host ebsapp1
  description ebsapp1.xxxx.lk
  ip address 172.25.45.19
  conn-limit max 4000000 min 4000000
  probe icmp-probe
  probe http-probe
  inservice
rserver host ebsapp2
  description ebsapp2.xxxx.lk
  ip address 172.25.45.20
  probe icmp-probe
  probe http-probe
  inservice
serverfarm host ebsppsvrfarm
  description ebsapp server farm
  failaction purge
  predictor response app-req-to-resp samples 4
  probe http-probe
  probe icmp-probe
  inband-health check log 5 reset 500
  retcode 404 404 check log 1 reset 3
  rserver ebsapp1 80
    probe icmp-probe
    inservice
  rserver ebsapp2 80
    probe icmp-probe
    inservice
sticky http-cookie jsessionid HTTP-COOKIE
  cookie insert browser-expire
  replicate sticky
  serverfarm ebsppsvrfarm
class-map type http loadbalance match-any default-compression-exclusion-mime-type
  description DM generated classmap for default LB compression exclusion mime types.
  2 match http url .*gif
  3 match http url .*css
  4 match http url .*js
  5 match http url .*class
  6 match http url .*jar
  7 match http url .*cab
  8 match http url .*txt
  9 match http url .*ps
  10 match http url .*vbs
  11 match http url .*xsl
  12 match http url .*xml
  13 match http url .*pdf
  14 match http url .*swf
  15 match http url .*jpg
  16 match http url .*jpeg
  17 match http url .*jpe
  18 match http url .*png
class-map match-all ebsapp-vip
  2 match virtual-address 172.25.45.21 tcp eq www
class-map type management match-any remote_access
  2 match protocol xml-https any
  3 match protocol icmp any
  4 match protocol telnet any
  5 match protocol ssh any
  6 match protocol http any
  7 match protocol https any
  8 match protocol snmp any
policy-map type management first-match remote_mgmt_allow_policy
  class remote_access
    permit
policy-map type loadbalance first-match ebsapp-vip-l7slb
  class default-compression-exclusion-mime-type
  class class-default
    compress default-method deflate
    sticky-serverfarm HTTP-COOKIE
policy-map multi-match int455
  class ebsapp-vip
    loadbalance vip inservice
    loadbalance policy ebsapp-vip-l7slb
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 455
interface vlan 455
  ip address 172.25.45.36 255.255.255.0
  peer ip address 172.25.45.35 255.255.255.0
  access-group input ALL
  nat-pool 1 172.25.45.22 172.25.45.22 netmask 255.255.255.0 pat
  service-policy input remote_mgmt_allow_policy
  service-policy input int455
  no shutdown
ft interface vlan 999
  ip address 10.1.1.1 255.255.255.0
  peer ip address 10.1.1.2 255.255.255.0
  no shutdown
ft peer 1
  heartbeat interval 300
  heartbeat count 10
  ft-interface vlan 999
ft group 1
  peer 1
  no preempt
  priority 110
  associate-context Admin
  inservice
ip route 0.0.0.0 0.0.0.0 172.25.45.1
Hope you will reply me soon
Thanks....!
-Amal-
Hi Amal,
You have mentioned port 8000 for servers which your customer needs to access but you have mentioned port 80 under serverfarm for rservers. You should change it to 8000 if servers are listening on port 80. Your servers are working because they must be listening on port 80.
failaction purge
probe http-probe
probe icmp-probe
rserver ebsapp1 80------------>80 should be replaced with 8000
probe icmp-probe
inservice
rserver ebsapp2 80------------>80 should be replaced with 8000
probe icmp-probe
inservice
According to the below information the rservers seem to be listening on port 8000 and not 80 which you have configured.
    • IP : 172.25.45.19
    • Protocol: http
    • Port: 8000
    • IP : 172.25.45.20
    • Protocol: http
    • Port: 8000
Kanwal
Hi Amal,
in above i wanted to say "you should change the port to 8000 under serverfarm for rservers if servers are listening on port 8000". By mistake i have mentioned 80:)
Kanwal
Dear Kanwal,
Seems like it's working for me, but still I didn't able to get their login page but I was able to recived following attached page. what else more I have to do for this ?
Thanks...!
-Amal-
Hi Amal,
If you click on that link does it redirect you to login page? May be server sends a redirect and client should come with new url and then lands on login page. Not sure how the application works. What is the url you use to access the server directly?
Kanwal
Dear Kanwal,
When I clicked it, it doesn't redirect to any where. My client gave me the (http://ebiz.xxxx.lk)  as direct URL to access the App login page.
Thanks...!
-Amal-
Hi Amal,
Are you able to access the server directly with that URL and page opens? Can they provide you pcap of working session when client accessess the server directly. Do you see that your request is going to the correct serverfarm? Can you check in "show conn" output?
Kanwal
