NNTP and IPSec/VPN on ACE module
moabdallah
Does the Application Control Engine ACE support NNTP protocol ?
Does the ACE module support IPSec/VPN ? OR Do I need another module on the Cat-6500 tp support IPSec/VPN?
Mohamed
Gilles Dufour
Mohamed,
if you are talking about loadbalancing ipsec/vpn, the ACE module can do it.
If you want to terminate a VPN tunnel on the ACE module, this is not a function of the module.
I believe nntp works over tcp/ip so you should be able to loadbalance it.
Gilles.
