Problem with stickiness in CSS
ps_support
Community Member
I'm trying to configure a stickiness for wireless clients ( mobile phones) that accessing our sites through WAP gateway.
After doing some manual reading and some testing I created the following configuration that still doesn't work:
service server1
ip address 10.10.10.1
port 80
protocol tcp
keepalive port 80
keepalive frequency 10
keepalive uri "/heartbeat"
keepalive type http
active
service server2
ip address 10.10.10.2
port 80
protocol tcp
keepalive port 80
keepalive type http
active
header-field-group wap
header-field 4 custom "x-up-calling-line-id" contain "34"
content http
vip address 10.10.5.10
port 80
protocol tcp
add service server1
add service server2
active
content wap
url "/*"
protocol tcp
port 80
add service server1
add service server2
advanced-balance wap-msisdn
header-field-rule wap
no persistent
active
theoretically it should check whether x-app-calling-id header contain digits 34 - in case of existence it should perform a sticky connection to the same server all the time ,if not it should go to standard http connection that is load balanced with round robbin
Gilles Dufour
is the traffic matching the wap rule but not sticking, or is it matching the http rule.
Just want to see what we have to troubleshoot.
Do you have a trace of the client traffic so we can see what it countains.
Thanks.
Gille.s
First of all thanks for the response.
#show rule test-1 test-wap services
The output is :
server1 6,521,242 S-1 Alive 25 HTTP-80:H 0 0
server2 5,494,544 S-1 Alive 18 HTTP-80:H 0 0
so i guess it hits the rule
I also have about 1 million hits on the http rule.
So i guess the rule is being hit but the stickiness is not working correctly.
Are there any specific commands you can recommend to troubleshoot?
if the problem is stickyness, the problem is that the CSS can't find the MSISDN tag.
This is the only place we look for the client id.
Get a sniffer trace and see if this tag is there.
Gilles.
