Problems with transaction-logs on cache engines
alalli
Level 5
Level 5
Good Day All,
I have a Cache Engine 550 here and the transaction log working.log file got quite large.
I was not able to export it to my ftp server so I logged into the Cache engine via ftp and downloaded the file to a PC.
I then deleted the working.log file on the Cache Engine and rebooted the cache engine.
The working.log file was not re-created as I had hoped it might be.
I have created a file called working.log in the correct directory. This file does not seem to get updated though so this must not be right either.
Any suggestions?
regards,
amanda
Zach Seils
Level 11
Level 11
Amanda,
What version of ACNS are you running? Can you please try disabling and re-enabling transaction-logging?
Can you post the output of the command 'show transaction-logging'?
regards,
~Zach
Hi Zach,
Thank you so much for writing back. I am running an archaic version of the software... i can check tomorrow. As to the logging.... i had not enabled transaction-logging in itself so it was a silly config error ...
🙂 amanda
