Same VIP for multiple applications
Keong.leow
Community Member
I am doing GSLB between two sites using CSS.
I am supposed to use same VIP address for different applications in each site.
example
dns-record A www.test.com 1.1.1.1 60 multiple kal-icmp 1.1.1.1
content 1
add service 1
port 8080
vip addresses 1.1.1.1
active
content
add service 1
port 443
vip address 1.1.1.1
application ssl
advance-balance ssl
active
content 3
vip address 1.1.1.1
service 1
port 8443
advance-balance ssl
active.
clients acces by specifying hostname:port to access particular appliation.
The issue is even though the application on port 8080 is down on onesite the CSS responds with VIP 1.1.1.1 when client requests for www.test.com:8080 as the DNS A-record is active becoz of other application(content 2 and content3).
Is there any specific configurations in the CSS to avoid mentioned situations other than using different vip address for different applications..
Thanks in advance !!!
Gilles Dufour
change your dns-record keepalive from icmp to tag. Then specify a tag under the content rule 8080 config with the command 'add dns '.
Gilles.
Gilles,
What about if content 2 and content 3 is down?
do i need to add three dns A records with keepalive tag with different tag for three contents.
Gilles,
The available keepalives in the dns-record are kal-ap,kal-ap-vip,kal-icmp,kal-none and i didnt find the option for adding keepalive tag.
could you please provide more information on this.
Thanks in advance
the one you need is kal-ap.
This is documented at
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_configuration_guide_chapter09186a0080577cef.html#wp1119543
You have to understand that an name is linked to an ip address [not an application].
So, you can easily failover when the primary one is down or if they are all down.
If you want to failover when any is down, it is a little bit more complicated.
One way to achieve it is create a fake service that use a custom script to monitor all your vip. You use this fake service in a fake content rule that you monitor with kal-ap.
When this fake content rule goes down, it means one of the other content rule went down, and gslb will failover.
There might be other solution, but nothing direct.
Gilles.
