Script failed to load. Is script present on disk?
aliver
Level 2
Level 2
Good day!
after upgrade WEbNS to 7.50.1.03 services,which has script keepalive does not UP and return error "Script failed to load. Is script present on disk?". Although after reload with new WebNS all needed scripts was been uploaded to CSS. I see theirs via "show scripts" and successfully run via "script play ...", but services does not see its.
Why?
Thanks.
Gilles Dufour
if they were uploaded to the CSS after reboot, then it's too late. The CSS already tried to load the scripts and it only try once.
Do another reboot or unconfigure all the scripts and then reconfigure them.
Gilles.
Thanks, Gilles!
I try and see this 10 min prior your reply 🙂
I'm glad you found a solution.
I would give you a 5, except I have no proof you found the answer 10min before me 😉
G.
