Scripted Keepalive Problem
d.parks
Level 5
Level 5
I've run into an issue with a new scripted keepalive. I've created the script and copied it to a CSS11000. I can run the script manually and it works as expected, however when I add it to a service, it is not run. After the service is activated, the service shows down, and the following information is shown for the script:
Script Error: None (suspended)
Script Run Time: Did not finish
I know I've run into similar issues when upgrading the CSS code. After restoring archived scripts within the new version, I'd have to reboot the CSS before I could use them in keepalives.
I'd prefer not to have to reboot my production switches if there is another way to get this to work.
sean.cheney
Level 2
Level 2
It's been my experience that you're gonna need another reboot. I've never been able to get a workaround for this...
Gilles Dufour
suspended and did not finish indicates the script hangs.
We had a bug a couple months ago related to this - CSCdy74475
Not sure which version you are using but it's worth to look at.
Gilles.
Thanks Gilles,
I am quite backlevel on this particular pair of CSS's. I loaded the newest code on a CSS in the lab and did not have this problem.
Looks like I need to schedule an upgrade for the production boxes.
-Dominic
