Simple Load Balancing Config not working
HEATH FREEL
Level 7
Level 7
I have a very simple set up that I have done before, but this one isn't working.
Virtual 10.1.1.1:80
Real 10.1.1.2:80
Real 10.1.1.3:80
Bind 10.1.1.1:80 10.1.1.2:80
Bind 10.1.1.1:80 10.1.1.3:80
I can connect to each server separately but when I use the Virtual IP I keep getting the same server - 10.1.1.2:80
When I do a show real - connections for both servers sit at 0.
Any Ideas??
hhesketh
Community Member
HI there,
I'd create a layer three rule with syntax something like:
content L3rule1
y
add service state1
add service state2
balance leastconn
protocol tcp
no persistent
port 80
vip address 172.24.188.20
this would force leastconnection load balancing,
and hopefully resolve the problem,
cheers,
Hamish
hhesketh
Community Member
do a show service - this gives good pointers on where there are problems
