SLB ios 6500 - probe http problem
m.maiorino
Community Member
I've a 6500 Msfc2 with IOS 12.2-18Sxd5 configured for SLB. The problem is about http probe with a Microsoft IIS6.0 on win2003. I 've found in bug toolkit the issue (CSCeb68312) marked as resolved but for 6500 platform the last IOS release is only 12.2-18Sxd6. Can I use this version to solve the bug ?
Thanks.
Massimo
smahbub
Level 11
Level 11
You can use the 0-port vservers in conjunction with HTTP probes.
Either make the vservers port-specific, or use TCP or ICMP probes.
Iguess for Cat 6K the fix is available from - 12.2(19.7)S
