SNAT not working on ACE4710
akhil.abrol
Hi All,
I've been trying to do SNAT on ACE but for some weird reason its not happning. We have 6 ACE 4710 appliances, except on 1 SNAT is working fine with similar config on other ace appliances.
Please help as the customer needs this application asap. Here is the config.
rserver host SPB-37
  ip address 172.18.128.37
  inservice
rserver host SPB-38
  ip address 172.18.128.38
  inservice
serverfarm host SPB-SRVFARM
  predictor leastconns
  probe TCP-7001
  rserver SPB-37 7001
    inservice
  rserver SPB-38 7001
    inservice
serverfarm host SPB-SRVFARM-30389
  probe ICMP-ICMP-Probe
  probe TCP-30389
  rserver SPB-37 30389
    inservice
  rserver SPB-38 30389
    inservice
class-map match-any SPB-30389-VIP
  2 match virtual-address 172.18.133.25 tcp eq 30389
class-map match-any SPB-VIP
  2 match virtual-address 172.18.133.25 tcp eq 7001
policy-map type loadbalance first-match SPB-30389-l7slb
  class class-default
    serverfarm SPB-SRVFARM-30389
policy-map type loadbalance first-match SPB-l7slb
  class class-default
policy-map multi-match All_Policy_Maps
  class SPB-VIP
    loadbalance vip inservice
    loadbalance policy SPB-l7slb
    loadbalance vip icmp-reply
    nat dynamic 28 vlan 128
  class SPB-30389-VIP
    loadbalance policy SPB-30389-l7slb
interface vlan 98
  description *** Server Vlan ***
  ip address 10.105.98.180 255.255.255.0
  alias 10.105.98.181 255.255.255.0
  peer ip address 10.105.98.182 255.255.255.0
  access-group input ALL
  nat-pool 98 172.18.133.128 172.18.133.128 netmask 255.255.255.255 pat // This works fine.
  service-policy input remote_mgmt_allow_policy
  no shutdown
interface vlan 128
  ip address 172.18.128.8 255.255.255.0
  alias 172.18.128.7 255.255.255.0
  peer ip address 172.18.128.9 255.255.255.0
  nat-pool 28 172.18.135.165 172.18.135.165 netmask 255.255.255.255 pat  // This doesnt work.
  no shutdown
interface vlan 133
  description *** Client vlan ***
  ip address 172.18.133.5 255.255.255.128
  peer ip address 172.18.133.6 255.255.255.128
  service-policy input Service-Policy-IDAM-7777
  service-policy input SDP-SE
  service-policy input Service-Policy-SDP-NT-8001
  service-policy input Service-Policy-SDP-Deliver-7002
  service-policy input Service-Policy-SDP-Deliver-7007
  service-policy input Service-Policy-SDP-Deliver-7006
  service-policy input Service-Policy-SDP-RE
  service-policy input Service-Policy-SDP-SE-7002
  service-policy input Service-Policy-SDP-SE-7101
  service-policy input Service-Policy-SDP-RE-7101
  service-policy input All_Policy_Maps
  no shutdown
Gilles Dufour
the problem is this :
policy-map multi-match Service-Policy-SDP-NT-8001
  class SNAT-Outside
    nat dynamic 98 vlan 98
This policy shows up before the one you identified
interface vlan 133
The class SNAT-Outside is a match 0.0.0.0/0 so it will match all your traffic.
Therefore, the nat action will be : nat dynamic 98 vlan 98.
Since traffic goes out vlan 128, there is no rule to nat the traffic.
Multiple solutions.
1/ remove Service-Policy-SDP-NT-8001 and add it after  All_Policy_Maps
2/ add "nat dynamic 28 vlan 128" under Service-Policy-SDP-NT-8001
   class SNAT-Outside
Gilles.
Gilles Dufour
  class SNAT-Outside
interface vlan 133
Multiple solutions.
   class SNAT-Outside
Gilles.
Hi Gilles,
Thanks for the solution. I was expecting a reply from you only.
Have a wonderful day.
Cheers.!
