SNMP issues in monitoring WAE
dany.datacraft
Hi guys,
Just wondering if you have experienced this issue somewhere else and if you have any resolution to it?  We are currently trying to monitor 2 x WAE-694-K9 in our data centre via SNMP.  1 of them works, the other doesn't.
WAE-01 does not work and what we see:
* CPU utilization is around 13% and this will drop to 1% if we remove the snmp community configuration.  When we add back the snmp community, the snmpwalk is responsive once but after a while it will go back to 13% and the snmp is no longer responsive.
* We did a packet capture and we are seeing the SNMP request coming to the WAE via the correct interface.  There is no reply from the WAE.
* The CLI respond is quite sluggish, for example when we execute the 'show run', it takes approximately 8-10 seconds for the first line to appear and when we do a 'term len 0' before the show run, the config appears line by line with about 1 sec delay in between.  The initial delay happens for all commands, not just 'show run'.  We suspect this is related to the CPU utilization of 13% that we see in this WAE.
WAE-02 works and what we see:
* CPU utilization is around 1%.
* We did a packet capture and we are seeing both SNMP request and respond.
* The CLI respond is not sluggish.
SNMP Configuration between the two WAE are exactly the same.
Saw this bug CSCsm28839 but both WAEs are being monitored by two servers.
dany.datacraft
Ping...
