Waas disc replacement
guillermo.deleon
Frequent Visitor
Frequent Visitor
I need change a couple of disk in Wae 512. My question is, Is neccesary run the recovery waas image disck? or only I need to change the disk's.
jujouber
By default the WAE 512 ships with 2 X 250 GB HDD in a RAID 1 disk array. If you are replacing only one disk the RAID should rebuild when the disk is replaced.
If you are replacing both disks, you will need to rebuild using the recovery CD.
Thaks for your Reply. I need to chance both disk. So, When I made the change I need to Use de Recovery Disck and choose the option 7. (Erase data and rebuild the RAID). Every works so good!
thanks
