WAAS load balancing
pthaynes
Level 2
Level 2
I have two WAAS devices in my head office site doing load balancing and a number of remote sites each with a single site. Within the WAAS central manager web site if I look at Acceleration > topology for my load balancing WAAS devices I see a peer that looks like a MAC address. I can't find that MAC address on any of my WAAS devices, but I am suspicious that it relates to the other load balancing WAAS. Is this normal?
Zach Seils
Level 11
Level 11
Peter,
You can view the MAC address used as the WAE ID with the following command:
show tfo status
You can also view statistics on a per-peer basis with the command:
show statistics tfo peer
Zach
Zach Seils
Level 11
Level 11
Peter,
show tfo status
Zach
Zach,
Thanks for your reply. The show statistics tfo peer showed that the peer hadn't communicated for a while, and the last contact time coincided with the date that we replaced a broken WAE NM. So the mystery is solved.
