WAAS over PPPoE
PauloHirakawa
I´m having a problem to register a Branch WAE in Central Manager over a DMVPN network through a interface dialer (PPPoE).
The Branch Office has two links, one dedicated and one PPPoE. These connects the central over GRE tunnel interfaces with OSPF.
When the main tunnel goes down (Dedicated link) the backup assumes the connection but in the Central Manager, the branch waas is offline.
This is the only branch that has PPPoE link. In others I have no problems with redundancy.
I´d like to know if there are limitations to register waas module over PPPoE link.
Any ideas to solve this problem.
PS: waas module is configure with
Router#
interface FastEthernet0/0/0
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Integrated-Service-Engine1/0
ip address 192.168.254.17 255.255.255.252
ip wccp redirect exclude in
service-module ip address 192.168.254.18 255.255.255.252
!Application: Restarted at Mon May  8 21:06:15 2006
service-module ip default-gateway 192.168.254.17
no keepalive
interface Dialer1
mtu 1492
ip address negotiated
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username digitalxxx password 7 130146155A185026797020
WAE#sh run
! WAAS version 4.1.5e (build b5 Feb 23 2010)
device mode application-accelerator
hostname xxxxxxx
clock timezone Brazil/East -2 0
ip domain-name xxxxxx
primary-interface GigabitEthernet 1/0
no autosense
bandwidth 1000
full-duplex
exit
interface GigabitEthernet 2/0
shutdown
exit
no auto-register enable
ip path-mtu-discovery enable
output omitted
Thanks!!
6 Replies 6
Daniel Arrondo Ostiz
Hi Paulo,
I don't see any reason why the connection type would have any impact in the communication between the NME-WAE and the central manager. As long as the two devices have IP connectivity, it should appear as online in the central manager.
From what you described, the first thing that comes to my mind is a possible routing problem. Are you sure that, when the primary link goes down and the PPPoE comes up, both devices still have all the necessary routes to communicate between them?
Yes, it is very strange.
I can ping from NME-WAE to Central Manager normally.
Hi Paulo,
Pinging from the NME is not an ideal test, because it could work if there was some kind of dynamic nat between it and the central manager. Instead, what I would recommend you to try is pinging from the central manager to the management IP of the NME (the one that appears in the web interface of the central manager)
If this works, you should also check if there is anything in the path configured to block TCP port 443, which is the one used for the communciation between the devices.
Hi Daniel,
I tried it and ping from CM to NME-WAE is OK. I dont know about the router from ISP if there is some filter but I will try contact this ISP.
We have about 12 routers with the same config with two ISP´s redundant link and this is the only I have problem and  the only PPPoE.
CM#ping 192.168.254.18
PING 192.168.254.18 (192.168.254.18) 56(84) bytes of data.
64 bytes from 192.168.254.18: icmp_seq=1 ttl=61 time=16.4 ms
64 bytes from 192.168.254.18: icmp_seq=2 ttl=61 time=14.5 ms
64 bytes from 192.168.254.18: icmp_seq=3 ttl=61 time=14.5 ms
64 bytes from 192.168.254.18: icmp_seq=4 ttl=61 time=14.8 ms
64 bytes from 192.168.254.18: icmp_seq=5 ttl=61 time=29.7 ms
--- 192.168.254.18 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 3999ms
rtt min/avg/max/mdev = 14.566/18.036/29.724/5.888 ms
Hi Paulo,
If you still don't find anything in the router that may explain why the traffic is being dropped, then, I would suggest you to open a TAC service request to have it investigated further.
Daniel
Ok Daniel,
Thanks for your help.
