WAAS using WCCP with gre tunnel going via vpn
donaghq_2
Hello All
I am trying to get WAAS using WCCP to work according to the attached diagram. I would like to know if there is a redirection config that I need to apply to the ASAs?
Many thanks
Donagh
Zach Seils
Level 7
Level 7
Donagh,
Since you have WCCP configured on the 2811's, no WCCP configuration in required on the ASA appliances.
Zach
Thanks Zach. I will test this out and then update this conversation.
Donagh
